The Blackout Blind as the name suggests excludes light when closed. It is commonly used in Lecture Theatres, Photographic Laboratories, Schools & Colleges etc in the Commercial Market and Operating Theatres, Light Sensitive Testing Areas in the Health Market.
The Linea 400 Fully Framed Blackout Roller Blind is a Heavy-Duty versatile system incorporating all of the attributes expected of this type of product.
Aesthetics - The aluminium extruded headbox is 100mm square and is powder coated black or white as standard but can be coated to any RAL colour upon request.
Stability - The 75mm side profiles are moulded in tough ABS and have been specially designed to eliminate light ingress and to ensure that the fabric remains in position.
Limited Noise - The bottom rail is rigid in section enabling large widths of windows to be screened. Moulded bottom rail reducers are used at each end of the rail so that metal to metal contact is avoided in operation of the blind. This ensures quiet and smooth operation.
Operation - The blind is available to operate by using tape, gear with handle, spring or motorized.
Adaptable - The blind can be used to cover standard window openings and, horizontal and sloping skylight applications.
